It is currently Thu Sep 10, 2026 10:09 am
PostPosted: Tue Mar 03, 2026 12:59 pm
(Admin edits... this is a Hobie Wave. If there are tracks that the trampoline attaches to the hull (Looks like it)... it would be a Club version)
I have a Older Hobie Wave, and just recently the jib sheet cleat broke off the the hull... Looks like original well nuts corroded. So I am looking on advice to replace ( Rubber Well Nuts or Thread Brass Inserts ) and any tips on sizes before I go drilling an poking around.
PostPosted: Wed Mar 04, 2026 12:05 am
Installing a small deck port in the deck above this area would allow thru bolts and backing washers/nuts. That would be solid. drill through the remaining molded-in insert. I suspect it is aluminum if it corroded.
