It is currently Wed Aug 26, 2026 6:34 am
 Post subject: Furler rebuild help
PostPosted: Fri Oct 12, 2007 6:15 pm
I have an old Hobie Furler from an 82' H18; I just bought the boat used. The furler wasn't working so I bought and installed the rebuild kit. Now I can't get any spring tension (not sure if it had it before). Everything just spins. How do you tension the furler? Thank you for any help.
1982 Hobie 18
PostPosted: Fri Oct 12, 2007 6:48 pm
Hobie 18 furler has no spring tension. The jib sheet pulls the sail out and the furler line rolls it in. The jib is all out or all in. You can't sail the jib partially furled.
1989 Hobie 18 Worlds Boat, Magnum Wings & Spinnaker
1987 Hobie Holder 20 #273
dale.vanlopik"at"att"dot"net
PostPosted: Sat Oct 13, 2007 5:19 am
Ahhh...now it all makes sense. Thanks for the info.
1982 Hobie 18
