It is currently Sat Aug 08, 2026 8:42 pm
PostPosted: Fri May 09, 2008 5:00 pm
Hi
This my first time re-assembling my Getaway after two months of use and then storing it for a month. There is no label on the tiller crossbar for starboard or port. Does it make a difference(qm). how to tell which side is right; angle of the extension bracket hole(qm).
Also, there are no instructions in the manual for de-stepping the mast. Is it the reverse of the stepping instruction(qm). Do you rotate the mast as you step back(qm).
Lew
