It is currently Sun Aug 09, 2026 7:06 am
 Post subject: Comp tip cracking
PostPosted: Mon Jun 13, 2011 7:54 pm
I have searched the forums and have found a lot of useful information on comp tip problems and repair. I have a slightly different question then what has already been discussed.
I just purchased my getaway (and loving life). I have spots on my comp tip that are cracking...horizontally. It appears that the prior owner may have damaged it in the Handling/storage as they do not appear to be stress related ( my assumption given they are horizontal and prior post on the subject).
When I look into the mast thru the crack there appears to be a solid core. Does anyone know if the black outside is just a shell and therefore most of the support is provided for by the core versus the black shell. Is the black shell just a protective covering or does it provide something in the support structure.
Thanks for any and all help.
 Post subject: Re: Comp tip cracking
PostPosted: Tue Jun 14, 2011 8:58 am
Yes, the outer black material is just cosmetic putty. Some vintages seem more prone to crazing (cracks).
