It is currently Sat Aug 08, 2026 10:41 pm
PostPosted: Mon Jan 19, 2015 10:26 am
So, last fall, while taking apart the Getaway (2006 model) for winter storage, I found that I was having real trouble separating the tiller bar from the rudder arms. Those little black rubber tendon elbows on each side were really stuck in there, to the point where I simply could not move them. I applied a little bit too much percussive maintenance (ie. with my foot) and ended up shearing the damn things clear off.
So now, I am probably going to have to drill them out and replace them. Couple of questions have arisen as a result:
1) Does anyone have any best practices about how to work these loose next time? Is there a lubricant that can be applied during setup? I can tell you how NOT to do it...
2) Does the EZ-loc system work the same way, and is there an upgrade path? Just wondering if going to the EZloc system is even an option.
Cheers
PostPosted: Mon Jan 19, 2015 10:50 am
Replacement tendons are a better material, so should not cause you issues in the future.
You can change the tiller connectors without changing the rudder system. I would get the 1957 kit.
https://static.hobiecat.com/item_attachments/1957z52.pdf
PostPosted: Fri Feb 27, 2015 4:24 pm
That is a great answer Matt, thanks. Appreciate the instructions as well.
