It is currently Sat Aug 08, 2026 7:51 pm
PostPosted: Tue Feb 03, 2015 9:49 pm
I took apart my furler because the furler drum seemed to be sticky. I was appalled. The thrust bearings were corroded pretty badly with about 4 of them seized completely to the ring. Matt, can you provide the dimensions so I can purchase some stainless replacements? If these were supposed to be stainless, you got a bad batch from your supplier.
R/Thom
SeaRail 19
Triak
BMW C600
Formerly raced F24 Mk II
PostPosted: Wed Feb 04, 2015 7:45 am
I've noticed the same with mine. I ordered the rebuild kit and will probably use bicycle waterproof grease on the bearings when I put it back together. It is not a high end assembly.
Sail More. Tinker Less. Enjoy a Hobie Day.
-2013 H16 #1`13780
-2014 Getaway w/wings,spinnaker,& trapeze
PostPosted: Wed Feb 04, 2015 8:33 am
In Hobie's defense, thrust bearing race ring stainless will usually corrode around the edges of the holes because the cutters are not stainless and leave some residue during the manufacturing process of cutting the holes in the ring. The compression rings on these are OK after I sanded the corrosion off, and I probably can salvage the race ring with some elbow grease and sandpaper. I normally haven't seen bearings completely seized like these are which means the stainless itself may not be very good grade in the race ring...and I can't know whether or not the previous owner of this boat hosed down the furler after sailing in salt water (I suspect not since he beach launched). I'll reassemble and see what it looks like in 6 months. But I probably will try to find an alternate supplier since the rebuild kit will likely be from the same supplier to Hobie as the original and will likely corrode just the same. The only critical dimension is the depth or thickness of the two compression rings and the race between. I may replace the whole thing since I'm not sanguine about forestay loads being supported by snap rings; but I haven't seen anyone post that their mast fell over because the furler came apart, so maybe it is OK.
R/Thom
SeaRail 19
Triak
BMW C600
PostPosted: Wed Feb 04, 2015 9:31 am
After taking it apart further and getting all the bearings out of the race ring, I have to apologize. The race ring itself is not stainless, it is rust colored plastic (it may have been a different color when new). SO, I have to blame the seized bearings on poor maintenance on the part of the previous owner. All of the bearings (and everything else inside the furler) have a brown residue on them which I thought was rust, but I suspect is tree sap or some other sticky substance.
R/Thom
SeaRail 19
Triak
BMW C600
PostPosted: Wed Feb 04, 2015 9:55 am
It is very common for blowing sand and dust to carry metallic particles. These stick to wires and fittings and rust in salt conditions.
PostPosted: Fri Feb 06, 2015 3:20 pm
Here is a little vid i found useful when i cleaned and regreased my furler.....
https://www.youtube.com/watch?v=OhrzlrgVEBk
•Present boat -1998 Hobie 16 Solana Sails furling jib[/size]
PostPosted: Fri Feb 06, 2015 3:41 pm
waldorf wrote:
Here is a little vid i found useful when i cleaned and regreased my curler.....
Two things that you can do instead of what's seen on the video and which is a little easier on you. First, you don't have to remove the large circlip, you can take it apart by just removing the small one and the screw. Second, insert the furling line and tie through the hole before lowering the top casing onto the shaft.
R/Thom
SeaRail 19
Triak
BMW C600
