It is currently Sat Aug 08, 2026 7:01 pm
PostPosted: Thu Feb 12, 2015 11:31 am
Hello,
I could use 2 replacement leg tension assemblies for my Getaway wings.
Before ordering up new ones I figured I would see if anyone had some used ones.
Ogre
2004 Getaway with wings
PostPosted: Mon Apr 06, 2015 8:18 am
Well......That was a major pain. :evil:
The wing leg screw design is a nightmare to get un-done after several years in saltwater use.
The threaded area is buried deep in the wing casting and of course being of dissimilar metals it was corroded together.
After breaking 3 Philips head impact driver bits and totally buggering the screw head I had to grind the head to fit a standard wrench.
Even with that it took a 3' long cheater bar. Thought I was going to snap that screw many times.
PostPosted: Mon Apr 06, 2015 9:42 am
I cannot believe they did not snap!
PostPosted: Thu Apr 09, 2015 1:16 pm
Personally I would have put SS bolts back in instead of the screws, that way at least you can get them out easier later on. Did you put a little silicone grease on the new ones before you put them in?
PostPosted: Thu Apr 09, 2015 6:21 pm
I used nickle based anti seize.
I am thinking of replacing them with cap screws.
I figured I might bugger up the screws so I ordered new ones when I ordered the new legs.
Had no idea it would have turned out as bad as it did.
PostPosted: Fri Apr 10, 2015 2:24 pm
I don't sail in salt water but if I did I would do a lot more maintenance than I do now.
