It is currently Sat Aug 08, 2026 7:00 pm
 Post subject: Mast Step Ball Lubricant
PostPosted: Sun Mar 29, 2015 12:54 pm
On days when the wind is variable and lite, my mast tends to swivel on the ball a lot. When it does, it tends to make a loud squeaking noise. Is there some sort of lubricant I should be using? Thanks!
2015 Hobie Tandem Island
Ivory Dune
Trampolines, Spinnaker Kit, Lowrance Hook4, Vantage Seat Accessory Bags, GoPro Hero3+, RTIC SoftPak 30, WaterPORT Day Tank
PostPosted: Sun Mar 29, 2015 5:11 pm
MCLUBE Sailkote Dry Lubricant. Available at West Marine. I use it to lube everything on the boat. Works great.
Dave
PostPosted: Tue Mar 31, 2015 2:48 am
Small dab of automotive bearing grease up inside the socket of the mast base.
PostPosted: Wed Apr 01, 2015 5:23 pm
Yeah I just throw some automotive grease onto the ball but need to do it each time I rig the boat. Would this spray negate the need to do it each time?
Secondly, I only had this problem when I replaced the the ball and mast base. First time it happened, it actually ground away some of the ball as well, but we had been sailing for a couple of hours before it started, so I am at a loss as to what cause it. Had it been sand or similar, it should have started making the noise straight away. Weird.
PostPosted: Wed May 13, 2015 4:02 pm
McLube is the only war to go!!
Been using it for 30 years. It can also make cleats, blocks and pulleys like new.
Rudder locks return to normal.
PostPosted: Wed May 13, 2015 4:50 pm
Go the to local discount store and buy a bag of practice "wiffle" golf balls. Cut one in half, exactly. Place this in the mast step indention and forego lubricants forever.
It will fit perfectly, provide a slip fit and won't tend to come out even when the mast is down.
