It is currently Sat Aug 08, 2026 6:49 pm
PostPosted: Mon Aug 31, 2015 8:28 am
Yesterday, we were taking down my mast of my 2004 Getaway when the mast got loose from my assistant. The tip with the mast bob hit the ground somewhat hard and the mast cracked. The crack makes the mast a wobbly. In other words, it's not broken off but not safe to sail. Can this damage be repaired or do I need a new mast?
The crack is about four feet below the mast tip.
The crack: Image https://goo.gl/photos/i2nc2ijADR4bTpVF6
Different angle on the crack: Imagehttps://goo.gl/photos/N8j4TPSU8fpPTPRs6
Front of the mast perspective on the crack: Imagehttps://goo.gl/photos/xb9KKhhenWW6rWEJ9
Opposite side from the crack: Imagehttps://goo.gl/photos/SMGx9VAQvE2c7YAT8
I couldn't get the inline images working but the photo links work.
Jeff
PostPosted: Mon Aug 31, 2015 8:53 am
That is a crack in the comptip (it's made of fiberglass)
Most anything can be patched - using polyester glass cloth and resins - see a dealer for help if you're unsure. Even if you do decide to buy a replacement - it's just the top section you'd be replacing, not the entire mast. So it's not as bad as you'd think.
Your closest Hobie dealers are:
1
SAILACTION
SOUTHAMPTON, NY 11968
1-631-283-8373
2
MEGREW'S BOATS
CHARLESTOWN, RI 02813
1-401-322-1150
3
THE BOAT LOCKER
BRIDGEPORT, CT 06605
1-203-259-7808
Jacques Bernier
http://www.hobie.com/
PostPosted: Mon Aug 31, 2015 10:33 am
Thanks - that's a great relief. how hard is it to replace the comp tip?
PostPosted: Mon Aug 31, 2015 11:00 am
Pretty straight forward. Just gotta break the epoxy free from the junction - heat of the aluminum extrusion first then use some force to break the two halves apart (sometimes this requires hooking one end to something solid and the on a trailer hitch on your car) Worse case you'll need to dremel all the old glass fibers out of the junction to install a new one - but you 'should' be able to get the two halves apart with some massaging.
Jacques Bernier
PostPosted: Fri Oct 02, 2015 3:53 pm
I repaired my mast but right at the top. so far it's been ok. where your's is would be a little more
involved. there is a good fiberglass guy in hampton bays..not remembering his name. I used epoxy
resin when i did mine..Sit down when you get the price on a Comptip..do you sail in Tiana? Doug
ps I use a Mast Stepper and really like it.
