It is currently Sat Aug 08, 2026 7:50 pm
PostPosted: Mon Oct 26, 2015 2:33 pm
I have a Getaway and the tramp track screws have pulled out of hull. Is there a backing plate on the inside of hull? Can I just get bigger screws to replace or will that cause the tramp not be able to slide along track? Any help would be appreciated.
Tadhg
PostPosted: Mon Oct 26, 2015 2:56 pm
They are simply screwed into plastic - you could oversize, or install inserts into the existing holes and re-use the current screws.
Jacques Bernier
http://www.hobie.com/
