It is currently Sat Aug 08, 2026 6:49 pm
 Post subject: mast clearance
PostPosted: Fri Jul 15, 2016 3:56 pm
I have a 2010 Getaway, I have several draw bridges that lead to the Gulf of Mexico. It would be much easier traveling if I need not wait on a bridge opening; to do this without testing (and possibly damaging something) I need to know the height of the boat/mast/Bob (the clearance). The bridge is 30 feet at center.
thanks
Jerry Malone
 Post subject: Re: mast clearance
PostPosted: Fri Jul 15, 2016 4:09 pm
Easiest thing to do might be to tip over your fully rigged boat in the grass and with an assistant take a tape measure from top of mast float following the path of the mast to the bottom of the hulls... make a straight line between the hulls with painters tape stretched so you know where the actual bottom is, maybe add 6" ect to allow for wave action up and down. I have a feeling you'll end up at about 29'.
Tim Grover
Memphis, TN fleet 134
Hobie 20! G-Cat5.0 and 2 Hobie 14's
Photobucket now wants $100 to post pics on forums......... pass.
PostPosted: Fri Jul 15, 2016 4:13 pm
You're good. HobieCat.com says the Getaway mast is 25' (7.62 m) tall, and there's no way the height of the Bob and the freeboard are more than 5' tall.
http://www.hobiecat.com/sail/getaway/specs/
Randii
PostPosted: Fri Jul 15, 2016 7:05 pm
Don't forget the tides!! I know they don't amount to much down there, but check them anyway.
R/Thom
SeaRail 19
Triak
BMW C600
Formerly raced F24 Mk II
PostPosted: Fri Jul 15, 2016 7:35 pm
Thanks for the tips/info. The tides here can vary up to 4 feet.
Fair winds and following seas
Jerry Malone
PostPosted: Mon Aug 01, 2016 1:55 pm
FYI: Charted bridge heights are from the Average of the High Tides, so MOST of the time that bridge is going to be more than 30 feet from the water, but SOMETIMES it will be less than 30 feet from the water.
