It is currently Sun Aug 09, 2026 12:45 am
 Post subject: Split in hulls
PostPosted: Sun Feb 03, 2019 9:03 pm
Hi all, A mate's 2004 Getaway has a split in the hull behind the rear beam. He got it plastic welded but it split again. Was thinking of add a 5inch round hatch on top of hull roughly 8 inches behind the beam and using that to access the inside of hull to then: Add aluminium or plastic plates with masses of something like Loctite PL PRemium to hold plate in place, then filling the crack with same. I would also add an aluminium Round plate (in halves) under the hatch to strengthen that.
He cant afford new hulls and there are no spare old ones in Australia.
Any thoughts at all?
Also has anyone tried this glue option..
https://www.permabond.com/2015/03/31/pr ... yethylene/
thanks J
 Post subject: Re: Split in hulls
PostPosted: Thu Feb 07, 2019 10:09 am
i would also bolt the plate, through the hull with carriage head bolts.
Yet another Bob!
Too many canoes and kayaks
PostPosted: Mon Feb 11, 2019 8:59 pm
Yep, sound idea thanks
PostPosted: Tue Feb 12, 2019 3:48 pm
Which hull? Port or starboard? I have a spare port hull if you're interested?
I'm in Tasmania so freight might be costly.
PostPosted: Tue Feb 12, 2019 3:54 pm
wow!! thanks for the offer, but its both hulls and yes freight would be ridiculous.
I had 8 great years in Tassie. Waters a bit cold for me, but love to sail with you next time I'm visiting..
Offer open other way if you like. I'm in Brissie.
PostPosted: Fri Feb 15, 2019 3:01 am
No worries.. Yes, weather is a little warmer in Brisbane but summer sailing in Tassie is still great!
