It is currently Sat Aug 08, 2026 11:27 pm
 Post subject: Jib head reattachment
PostPosted: Thu Jun 04, 2020 9:59 am
I need to reattach the jib head on my 2008 Getaway after the line making that attachment broke. I found a photo of this attachment area in a Hobie Getaway manual, but that photo shows a forestay and swivel assembly that does not look like the ones on my Getaway. I'm guessing that I should use the line to attach the grommet of the jib head to the thimble of the forestay. But any guidance on that would be appreciated. Thanks.
PostPosted: Thu Jun 04, 2020 10:33 am
Yes... with the forestay wire under tension! Critical!
If you tie it when the wire is loose you can then tear the jib when tension is on when rigged. Anchor one end and somehow place tension on the wire. Then tension and tie the line to just remove wrinkles from the sail luff... not too much! You could also do this with the boat rigged and tipped on its side on the shore.
PostPosted: Fri Jun 05, 2020 11:23 am
I sail in a pretty windy area, so jib luff tension is important (it's pretty important even in less windy areas, since the tension on the luff gives the jib the right shape). So I left some slack in the forestay when tying it. That dacron stretches a good amount before you need worry about it tearing. Later on, I shortened the top tensioner line and I added a second tensioner down at the furler drum so I could adjust the tension after rigging for the day's wind. A too loose luff is a guarantee of poor performance in bigger wind.
R/Thom
SeaRail 19
Triak
BMW C600
Formerly raced F24 Mk II
