It is currently Sat Aug 08, 2026 4:51 pm
PostPosted: Mon Jun 29, 2020 3:36 am
I always need to pass a low bridge to reach the best sailing area. The bridge is 6 meters above water.
With the sail down, jib rolled, and outboard running. I just tie a line from the forestay down on a small pulley on the front crossbeam, then back to the main sheet hook. The main sheet is fully pulled and cleated when the mast is up. When I get close to the bridge, I remove the forestay pin, loose the main sheet to lower the mast. After passing the bridge, I pull the main sheet to lift the mast up again, and put the pin back in the forestay.
I attached a video of me passing. I don't lower it too much to prevent damaging the mast base. I hold it just to prevent swinging on one side of the boat.
https://imgur.com/gallery/Ja4OZUY
Hobie Tandem Island "Sold"
WETA Trimaran "Sold"
Hobie Getaway
PostPosted: Mon Jun 29, 2020 8:42 am
It works. Nothing wrong with that!
You might want to consider something to keep the mast in CL, but that might be more work than its worth--it's not like you have a couple spare halyards.
R/Thom
SeaRail 19
Triak
BMW C600
Formerly raced F24 Mk II
PostPosted: Mon Jun 29, 2020 9:39 am
When lowered, the mast will lean on the wind direction. So if that day we are going upwind, the mast will lower directly in the center line. I don't fight it, I just hold the mast to be sure it lowers on a fixed direction based on the wind. Left, right, or center of the boat.
Hobie Getaway
