It is currently Sat Aug 08, 2026 6:41 pm
 Post subject: Masthead float questions
PostPosted: Wed Jul 22, 2020 9:12 am
I recently removed the masthead float from my 2011 Getaway so that I could clean it.
During cleaning I noticed two things that seemed odd:
(1) The mounting bracket puts the float at angle to the mast. Is my bracket bent or is this how it's supposed to be?
(2) While cleaning the float I removed the screw-on stopper seen in the photo above and I heard the distinctive sound of air being released from the float. Was that just a function of the normal atmosphere in the float having been heated --it's July in Texas as I do this-- or did I need to do something special now to refill this float with air? (That seems unlikely, but since I was asking about point #1 I thought I would ask about this as well.)
(2a) Assuming that the answer to #2 is "No, goofy, you don't need to fill the float with air" then what is the purpose of the screw-on stopper?
Thanks! --Matt
PostPosted: Wed Jul 22, 2020 10:27 am
Just heat expansion of the air. Good that is exhaled!
The bracket is bent. Should be square to the float / mast.
PostPosted: Fri Jul 24, 2020 8:54 am
Thanks, Matt. Is there a part number for just the bracket? So far I've only found a part that covers the entire assembly, which would be overkill.
Also, what is the function of the screw cap and this circular plug?
PostPosted: Fri Jul 24, 2020 9:13 am
Black drain plug.
The white spin-weld cap covers the rotomolding vent.
PostPosted: Fri Jul 24, 2020 1:35 pm
You can remove the brackets and bend them square again. No need to purchase new ones.
Ken
2013 Hobie Getaway
Portland, Oregon
PostPosted: Fri Jul 24, 2020 2:27 pm
Of course, that's been my plan if there's no way to get just a replacement bracket. Since the mast head float is an important safety feature, I don't mind springing for a new mounting bracket if possible.
PostPosted: Fri Jul 24, 2020 5:49 pm
They’re not bent too bad. You should be fine removing them and bending them back.
