It is currently Sat Aug 08, 2026 3:40 pm
 Post subject: Make your life easier
PostPosted: Fri Aug 28, 2020 12:43 pm
Hobie gives you standard split rings which are difficult to fiddle with each outing. You can cheaply replace them with something to make your ife easier.
https://smile.amazon.com/Split-Cotter-M ... 675&sr=8-2
https://smile.amazon.com/Split-Cotter-Marine-grade-stainless/dp/B078JJLB6W/ref=sr_1_2?dchild=1&keywords=stainless+split+cotter+rings&qid=1598643675&sr=8-2
If those links don't work, just go to amazon and search for split cotter rings. The marine grade rings have two bends the standard ones don't have...one points a piece down and away from the ring making it easy to spear the hole, the other has a bend toward the middle which will help do the same thing. Much easier to use, especially for folks (like me) whose hands are old and gnarly from many thousands of miles sailing.
R/Thom
SeaRail 19
Triak
BMW C600
Formerly raced F24 Mk II
PostPosted: Fri Aug 28, 2020 2:40 pm
The bit sticking out can be like a fishing hook. Tape over the ones you don't need to remove all the time.
I have a FAQ on rings:
Here are a couple of thoughts on clevis pins and rings (ring dings). They are definitely more secure than a quick release pin, so if you can learn to work with them they are the most secure connection. They don't require special tools. Small rings can be stiff, so a small blade driver to open may make them easier.
Normally you can pry open with your thumbnail. Place the nail in the ring within 1/8-1/4 inch of the end to pry open. push your thumb and forefinger in opposite directions to pry open. Slip onto the clevis pin and spin on.
Pry open with the clevis pin. Use the pin to wedge the ring open.
Pry open with a small tool.
There is a tool that holds them open for installation. Fishing shops may have that. Needle nose pliers or forceps work too.
Tape
I tape every ring that is not required to be removed. The ones at the anchor pin, twist toggle and shrouds (H16 / One side on other models requiring rig tensioning via the shroud). Tape helps to keep the rings from twisting out and covers the sharp ends that could catch on a sheet, rope or dock. Catching a line on a ring can pull them right out of a clevis pin. Also use boots over the adjusters. Use caution when pulling the boots down over the rings. Fold the ring flat against the adjuster / wire as you drop the boot down. This helps to prevent the boot from catching a ring and peeling it out.
Tape every ring that could possibly catch on lines or sails. This is especially true for spinnaker equipped boats or for longer voyages.
You can use a small piece of tape folded over the ring like bread on a sandwich or tape clear round the adjusters and rings several times.
PostPosted: Fri Aug 28, 2020 2:42 pm
PostPosted: Fri Aug 28, 2020 3:33 pm
Those are neat, for those sticking with ring dings. I wouldn't live without my quick release pins on the forestay and shrouds though, especially with tensioning the rig. I recently eliminated one more ring ding from my setup by installing a Ronstan Battlestick tiller extension, which uses a rubber coupling to attach to the tiller bar.
Ken
2013 Hobie Getaway
Portland, Oregon
PostPosted: Fri Aug 28, 2020 4:07 pm
There is another version of this that doesn't have anything pointing away from the ring so is less likely to catch on spinnakers.
https://westcoastsailing.net/ring-ding-5-8-inch-10-pack/
Matt is correct that one should tape these things each time but I can tell you that I don't do that and in 7000 miles of sailing day sails and races I haven't had any issues. Granted, there is always a first time. The thing is, even losing the rig (mine has come down a half dozen times over the years on different boats), there usually is no one hurt and no damage to the mast or boat. Again, there is always a first time.
Speaking for myself, I try to minimize PITA hardware as much as possible. Split rings are PITA if you have to remove them or put them back on; for equipment that doesn't have to be taken apart often, keep them.
R/Thom
SeaRail 19
Triak
BMW C600
PostPosted: Mon Aug 31, 2020 6:34 am
I always carry insulating tape to tape up all clevis pins. It's good seamanship to reduce risks where ever, it can easily be done, this being a case in point. A simple and cheap thing to do.
Ashus
Mirror, Bosun, Laser, Fireball, Hobie 16, Dart 18, IOR 1 Tonner, 1720, Ozgoose, Hobie Getaway
PostPosted: Tue Sep 01, 2020 1:20 am
I just started using a toggle pin with lanyard for the forestay, no issues as of yet. Shrouds are always connected to the boat even when trailering, so I kept the stock clevis pins.
Hobie Tandem Island "Sold"
WETA Trimaran "Sold"
Hobie Getaway
