It is currently Sat Aug 08, 2026 5:34 pm
 Post subject: Jib cleat updgrades
PostPosted: Fri Sep 10, 2021 8:51 am
The stock jib cleats have no vertical adjustment which is a pain when sitting on the wings and you need to adjust the jib. Has anyone found an upgrade cleat that has vertical adjustment that will bolt on? Or are there shims available that could be installed under the stock cleat?
thanks
Paul
Paul
2020 Getaway
http://www.fleet297.org
 Post subject: Re: Jib cleat updgrades
PostPosted: Fri Sep 10, 2021 9:01 am
You can bend the stainless swivel plate.
