It is currently Sun Aug 09, 2026 12:20 am
 Post subject: docking at berth
PostPosted: Mon Aug 06, 2007 7:43 am
Any tips for docking a getaway in a berth? I'm hating using the trailer & setting up and tearing down when I could just jump in & go.
PostPosted: Mon Aug 06, 2007 8:37 am
Don't do it.
It has been brought up a number of times and the advice is always constant.
The loose rigging on a cat will not survive the constant wave motion and the bottom of the hulls will get ugly.
I am sure Matt will elaborate.
PostPosted: Mon Aug 06, 2007 10:57 am
nerfrider wrote:
Don't do it.
Rats.
PostPosted: Mon Aug 06, 2007 4:15 pm
Take a look at http://www.hobiecat.com/community/viewtopic.php?t=6187
PostPosted: Fri Nov 02, 2007 5:41 pm
Check and see if you'd be allowed to use one of the slide on slide off floating docks tethered inside your other dock. You could tension the rigging after sailing, but you'd still have to remove the sails.
Have you thought about mast up storage?
Dan
Dan St. Gean
'82 H 18
'96 H Wave
