It is currently Sun Aug 09, 2026 12:20 am
 Post subject: Telo Cat
PostPosted: Mon Aug 13, 2007 1:22 pm
What type of wind indicator you guys use ? Does Telo Cat comes with some kind of attachment for Getaway furler?
The furler itself is kind of low. Is it still going to fit and be well visible to the sailer?
2 Hulls Cezar
PostPosted: Mon Aug 13, 2007 2:09 pm
Authorized Hobie Dealer
that wind vang will work on the getaway, I just went out in the yard and did a quick check, it can be just bellow the furler drum, as long as you can see the bottom of the drum you should be okay! Hobie part # 377
Brad Stephens
http://www.sunjammers.com
www.facebook.com/sunjammers
PostPosted: Tue Aug 14, 2007 8:31 am
Thank you for fast response. I cannot find this part in the catalog. Is it a wind indicator itself or attachment for Telo Cat for furler type jib??
2 Hulls Cezar
PostPosted: Wed Aug 15, 2007 12:49 pm
That part number is for a telo Cat wind Vane, it is on page 20 of the Hobie Catalog. you will also need a H18 adapter, to make it work with the Roller Furler. Let me know if you have any question.
Brad Stephens
PostPosted: Thu Aug 16, 2007 7:24 am
In my catalog it is #377 are we talking about the same thing?
2 Hulls Cezar
PostPosted: Thu Aug 16, 2007 9:46 am
Yep, same thing, I just messed the part number up, I have edited the post.
Brad Stephens
 Post subject: Telo cat
PostPosted: Mon Aug 20, 2007 2:14 pm
I used to use a telo vane on my H14Turbo which worked well. But on my Getaway the furler is way too low. The dealer warned me it would be and my friends H17 proved it as well. Wind tels work great. They grip on the sidestays and if you are tall enough you can get them up to where the wind indication is most important.
PostPosted: Tue Sep 25, 2007 6:35 pm
I installed one on my getaway in the spring. I found it necessary to drill a hole lower down on the ss square bar so the pointer would be positioned closer to the furler. I did a test fit first to get the right height. Works great.
