It is currently Thu Aug 20, 2026 4:59 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Tue Jul 29, 2008 6:07 pm
IndyWave wrote:
When I've capsized my Wave, I didn't have any problem righting it. I'm at about 205 lbs; and with the sheet uncleated and the righting line over the high hull, it popped right back up, very quickly! Both times, it was in strong winds (20+), so that may have helped.
After uncleating the sheet, I climbed up on the low bow (and let it pivot around to the wind), pulled the line out of the pocket, threw it over the high hull and leaned out. It popped up so quickly, I had to dodge the hull coming down and grab the other end of the righting line to keep it from rolling on over the other way.
For me the toughest parts were climbing onto the slippery bow, then getting back onto the boat after it was righted. I posted a solution to re-boarding the boat on Catsailor's Wave forum.
Since yours was so uncooperative, you might make sure you don't have water in the mast holding it down. Mine was filling up with rain water (from a leaky seal in the comp-tip joint) till I drilled two TINY holes in the luff track near the base. Water trickled out for hours. Now I can tell the boat is lighter when I pull it up on shore, so I'm sure it helped with righting also.
Hmmm, water in the mast, that would make sense. I don't trailer, I have a place to keep her. I did take the mast down last week to add some 303 to the float and comptip, seemed normal weight, but I did not drop it 100%, so some water could have been in there, staying at the base, undetected. Probably would not take much water to create a significant hinderance when righting. I will check into that situation. Thanks!
Jim
2007 Hobie Wave
PostPosted: Tue Jul 29, 2008 9:31 pm
I keep my mast up all the time too, so I didn't realize I had water in it until I took it down at the end of the season last year. Tipping it up and down (with my shoulder as a fulcrum) it sloshed quite a bit end to end, and the weight was pretty significant. It drip-dried out over the winter, but when I set it back up in the spring, it filled again with rain water fairly quickly.
Other people have talked about getting water in their comp-tips too, but I don't know what the fix would be for that.
What - Me Worry?
2006 Hobie Wave 7358
"Ish Kabibble"
PostPosted: Thu Aug 14, 2008 4:44 am
wannahobie wrote:
So why was this so difficult? I am thinking I should have untied the righting line on the lower point so I could use the entire 15' over the top of the upper hull, and lean way back. Was I supposed to untie?
Or perhaps I need to re-tie the righting line loops so that they are much smaller, to fee up a little more length.
Sorry for my late reply. I am new on this forum. Three month ago I bought my first sailboat - a Hobie Wave. I sail mostly in the Adriatic see and on Bohinj lake. I have not flown a hull yet but I did practice righting the boat at the shore. Standing in water I pulled the halyard at the side and tip the boat over. I am only 65kg in weight and I was surprised how easy is to right this boat. It is important that your righting line is long enough. The mast started to lift from water only if I leaned back far away from the hull and as low as possible (almost to the water surface). In this case the mast almost jumps in the air so one has to watch his head to move under the trampoline. In my opinion the key is the length of the righting line to be able to lean back with straight legs as low as possible.
Jernej
PostPosted: Sun Aug 30, 2009 2:49 pm
This summer I had a first experience in righting my wave in real conditions. I weigh only 67kg and I was able to right the boat with mast on the leeward side. Actually it was not so easy in that condition. I leaned back so far that I was touching the sea surface with my back. As the mast started to pop up I had to climb up the righting line keeping all my weight out of water. Next time I should point the mast to the winward side. Great experience.
Jernej
PostPosted: Fri Sep 04, 2009 8:32 am
Once one has capsized and successfully righted, the mystery and fear is gone, and one can go"balls out", fearlessly, henceforth.
I fly everytime I go out, now, sometimes for hours at a time. After which, my legs are wobbly, my butt is sore, the tops of my feet are chafed, and I have the biggest grin on my face for the rest of the day !
I like going fast, so the challenge becomes keeping the WAVE in that exact "sweet" spot angle where she's flying and screaming at the same time (about 30 degrees, I reckon). Too high, and she slows to a crawl. Sure, it's kind of cool to be way up in the air, looking around, but it is way cooler to go zooming, on one hull, past everything and everyone out there!
I especially like zipping past the kite surfers ! Their looks of surprise and chagrin crack me up everytime.
What a FUN FUN FUN little boat !
"HOBIE....
Say it LOUD and there's music playing...
Say it SOFT and it's almost like praying.....
I just sailed my WAVE out the Marina !"
West Coast Story
PostPosted: Fri Sep 04, 2009 9:46 am
Corey, contact me off list [email protected]
PostPosted: Mon Aug 24, 2015 8:51 am
DavidBell47 wrote:
Can you fly a hull on a wave. Just curious!!!!! :?
Happy Sailing,
David
https://www.youtube.com/watch?v=9fUEa7FRpCA :D
