It is currently Thu Aug 20, 2026 2:12 pm
PostPosted: Tue Sep 09, 2008 8:03 pm
I have decided that I am NOT going to take it easy this winter, like I did last, and plan on pushing my Hobie as far as weather conditions permit on any given day.
That said, I don't want to die of hyperthermia if I wind up in the drink.
Do any of y'all have a wetsuit recommendation? I am shooting for cost effectiveness and comfort.
PostPosted: Wed Sep 10, 2008 9:17 am
As long as we are talking wetsuits...
All new water wear from Hobie
(Inventory will be available to ship in early October)
<a href="http://static.hobiecat.com/linked_images/kayak/SizeChart.jpg">Click for Size Chart</a>
<img src="http://static.hobiecat.com/linked_images/kayak/3850XX_thumb.jpg" alt="">
<a href="http://static.hobiecat.com/linked_images/kayak/3850XX.jpg">Click for larger image</a>
HOBIE SPRAY TOP 99.95
3850SM / 3850MD / 3850LG / 3850XL
The Hobie Spray Top can be worn with swim trunks or over a wetsuit. Mix and match layers to get the comfort you desire. Spray and wind protection. Breathable 5000cm3 nylon shell.
Construction Features:
Neck and wrist seals
Neoprene waist seal
Offset chest pocket
Arm patch pocket
<img src="http://static.hobiecat.com/linked_images/kayak/3851XX_thumb.jpg" alt="">
<a href="http://static.hobiecat.com/linked_images/kayak/3851XX.jpg">Click for larger image</a>
HOBIE RASHGUARD - SHORT SLEEVE 27.95
3851MD / 3851LG / 3851XL
<img src="http://static.hobiecat.com/linked_images/kayak/3852XX_thumb.jpg" alt="">
<a href="http://static.hobiecat.com/linked_images/kayak/3852XX.jpg">Click for larger image</a>
HOBIE RASHGUARD - LONG SLEEVE 34.95
3852MD / 3852LG / 3852XL
Hobie Rashguard for comfort inside your wetsuit and great sun protection when you don't need a wetsuit. This short sleeve design and a high turtle neck style is ideal for any watersport where you need to be more comfortable in your wetsuit, the Lycra material with its 4 way stretch and tight fitting design will let your wetsuit slide on easy when you are getting ready and gives you more freedom when on the water. Raglan sleeve design allows the wetsuit to move so you do not get rubbed and sore - hence the name RASHGUARD - does what it says! The high neck Turtle neck design protects your neck from being rubbed by the suit when in salt water and a sand environment.
UV protection - this top is rated at 50+UPF which gives you the MAXIMUM PROTECTION from harmful UV rays - stopping over 98% of the rays getting to your skin! Ideal for use with board shorts on very hot days in exotic locations - so if you are off to the Caribbean in the winter make sure to pack your Hobie Rash Guard.
Construction - Made from 8oz Spandex Lycra with 4 way stretch and feature overlocked seams which are strong and robust.
<img src="http://static.hobiecat.com/linked_images/kayak/3853XX_thumb.jpg" alt="">
<a href="http://static.hobiecat.com/linked_images/kayak/3853XX.jpg">Click for larger image</a>
RED / BLACK
HOBIE - SHORTY 2/2 RED/BL 129.00
3853SM / 3853MD / 3853LG / 3853XL
SOLID BLACK
HOBIE - SHORTY 2/2 BLACK 129.00
3855SM / 3855MD / 3855LG / 3855XL
Hobie Shorty Wetsuit 2mm/2mm Great comfort for spring-like conditions. Add the Hobie Spray Top to further extend the cool weather comfort range. Add a rash guard for chafe protection. Vertical back zip entry.
Features:
Anti-choke neck
Armortex seat
Lumbar Flex Zone
Construction:
100% Dura Flex with mesh chest and back panels
Glued, Blindstitched seams
<img src="http://static.hobiecat.com/linked_images/kayak/3854XX_thumb.jpg" alt="">
<a href="http://static.hobiecat.com/linked_images/kayak/3854XX.jpg">Click for larger image</a>
RED / BLACK
HOBIE FULL WETSUIT - 3/2 RED/BLK 179.00
3854SM / 3854MD / 3854LG / 3854XL
SOLID BLACK
HOBIE FULL WETSUIT - 3/2 LG BLACK 179.00
3856SM / 3856MD / 3856LG / 3856XL
Hobie Full Wetsuit 3mm/2mm For colder days. Add the Hobie Spray Top to further extend the cold weather comfort range. Add a rash guard for chafe protection. Vertical back zip entry.
Features:
Anti-choke neck
Armortex knees
Lumbar Flex Zone
Construction:
