It is currently Thu Aug 20, 2026 2:13 pm
 Post subject: Wave cleaning
PostPosted: Mon Apr 27, 2009 1:49 pm
I purchased a used Wave model year 2002. What cleaners are safe to use on this type of hull? I have a Hobie 18 that I have wet sanded and buffed to bring back a gloss finish but I don't think that's the way to go with the Wave. There are a few black streaks on the outside hulls from the boat rubbing on the trailer rollers that I would like to remove. Also, the hull itself appears dull. Is this natural for this hull material? Any advice would be appreciated.
Thanks.
t-bone
 Post subject: Re: Wave cleaning
PostPosted: Mon Apr 27, 2009 3:49 pm
We have a boat cleaner that works very well.
New 2 part Hobie Boat Cleaner and UV Protectant System: Clean and then protect!
7005 HOBIE BOAT CLEANER 16oz $14.95
Formulated with "Green Chemistry"
You want to clean, but not scratch. The material is somewhat shiney when new, but certainly can oxidize and fade. Possibly someone has cleaned with an abrasive cleaner.
PostPosted: Mon Jun 15, 2009 5:14 pm
Can you buy this on your site somewhere? I just moved to a location where my Wave will be outside under a big dirty pine tree all the time. I know I'll need to clean it often now. Also wondering if anyne has rigged up a good cover to keep it (particularly the trampoline) clean?
PostPosted: Mon Jun 15, 2009 5:19 pm
Hobie Cat does not sell products direct to consumers. We manufacture and distribute for/to our authorized dealer network.
Use our Dealer Finder to find a dealer near you: http://www.hobiecat.com/company/dealer.html
Our cleaner will not handle Pine tree sap, so a cover would be good. We have a semi-custom tarp shown in the catalog that will work with the mast up: http://www.hobiecat.com/media/pdf/eSail ... _30-35.pdf (Page 32 "Universal" Covers)
PostPosted: Mon Jun 15, 2009 8:21 pm
My Wave sits on the shore under some tall, drippy, birdy trees also. You definitely want to protect your tramp!
I use a (roughly) 8' by 10' blue tarp from Harbor Freight Tools. You can usually find them on sale for about $5, and they last about half a year. A more expensive one might last longer, but usually by then it's gotten dirty enough from the trees, birds, etc... to be replaced anyway.
I use bungees (also bought in a bundle from Harbor Freight) to attach the front corners to the bow eyes, the back with a loop around each rudder, and for the sides I put a plastic hook (cut from the corner of a plastic coat hanger) in the channel of the front crossbar on each side, and bungee from the front corner, under the hook, to the eyelet behind the shroud. Then I have a dog-stake in the ground below the mast; and I run a bungee through that to the eyelet on each side of the mast
This covers the tramp completely and most of the hulls. It also covers the seat pads, so they stay clean and water doesn't sit on the access holes underneath. Only the bows and the ends of the sterns stick out. I have never had the cover come loose, even through some vicious storms.
What - Me Worry?
2006 Hobie Wave 7358
"Ish Kabibble"
PostPosted: Sat Jul 11, 2009 9:10 pm
My local dealer uses a power washer to clean their Waves and Getaways. I used one and it worked great with NO damage to boat, tramp, or other parts. Watch out for the decals because the power washer can strip them off.
PostPosted: Mon Jul 13, 2009 9:14 am
I use Dawn dish soap and a waterhose.
PostPosted: Fri Jun 24, 2016 7:15 am
I used a pressure washer and Magic Erasers to clean the hull.
Worked great. Just watch the decals and seat pads when pressure washing.
