It is currently Thu Aug 20, 2026 10:17 am
PostPosted: Sun Jun 20, 2010 7:44 am
Any suggestions the sleeve in the hull of my wave is sliding out were the cross bar goes in Thanks E
PostPosted: Mon Jun 21, 2010 9:52 am
How old is this boat?
The sleeves are molded into the hull and have some structure to grip the plastic. Perhaps gluing would be possible. I'd try West systems G-Flex.
PostPosted: Mon Jun 21, 2010 12:18 pm
04 is the year of the boat...sliding out in the back right hull about 1 inch on the inside so it hits the mount on the cross bar and will not sit fluss with the hull..so hull on right side is towed in.. Thanks E
PostPosted: Mon Jun 21, 2010 3:46 pm
I'd try the epoxy afer re-inserting the sleeve.
PostPosted: Mon Jun 21, 2010 6:35 pm
Interesting, did this happen as a result of "normal" use or was there an accident of some kind.
If normal use, do you sail in heavy air and waves a lot?
Charlie
PostPosted: Tue Jun 22, 2010 6:48 am
Only sail in Mexico Rocky Point with med. size waves ...no accident..E
PostPosted: Sun Jun 27, 2010 7:49 am
Matt Miller where can I pick up some west system G-Flex or will any expoxy work ..Thanks Eric
PostPosted: Thu Jul 01, 2010 11:53 am
The G-flex is described as excellent for Polyurethane applications. West Systems is available at Marine stores. Try West Marine?
http://www.westsystem.com
