It is currently Thu Aug 20, 2026 6:13 pm
 Post subject: type of rivets on rudder
PostPosted: Sat Sep 14, 2013 5:29 am
What type of rivets are used to join the upper rudder casting to the steering arm. Aluminium or SS. I want to replace to remove slop. They look shiny suggesting SS but I have read that SS should not be used with aluminium.
PostPosted: Sat Sep 14, 2013 10:18 am
For me the big deal was putting epoxy on the tiller when I put it back into the casting. After that you don't really need the rivets. I used stainless 'cause that's what I had, but as I said ...
Two years on and stall perfectly slop free, as you'd expect.
PostPosted: Mon Sep 16, 2013 8:50 am
Stainless.
Aluminum rivets have low shear strength, so we have to use Stainless rivets.
PostPosted: Thu Sep 19, 2013 9:02 pm
I have seen references to using Monel rather than SS rivets, which are preffered
PostPosted: Mon Sep 23, 2013 8:43 am
Like Titanium is better than aluminum... Monel-Stainless is better than stainless, but cost is an issue. We use stainless as the standard.
