It is currently Thu Aug 20, 2026 3:27 pm
 Post subject: Wave seat pads....
PostPosted: Sun Feb 02, 2014 1:39 pm
Just bought new ones, old ones breaking down giving us all blue-butt, (after only 2 years :( ) any tips for keeping the new ones healthy?
 Post subject: Re: Wave seat pads....
PostPosted: Mon Feb 03, 2014 9:44 am
I keep mine covered with a cheap tarp, lasted 8 years so far. But I'm on an inland lake, beached under tall trees.
What - Me Worry?
2006 Hobie Wave 7358
"Ish Kabibble"
PostPosted: Thu Jul 17, 2014 11:11 am
OK, ready to swap them out... any hints or tips on removing the old blue seat pads?
PostPosted: Fri Jul 18, 2014 6:08 am
I don't know if this is a hint or a tip, but I used a wide spatula, like you use for patching holes in your wall. About four inches wide I'd say. I started at one end and just worked it underneath and worked it side to side while I pushed. Didn't take long to peel up the whole thing. Or at least back past the port. That was the point in my case. To take out the ports and recaulk with silicone. My boat doesn't leak now.
Good luck!
PostPosted: Mon Jul 28, 2014 5:08 pm
Stuff like that could be helpful.
PostPosted: Sun Aug 24, 2014 7:02 pm
Hi Forum members: related question. My blue seat pads still in good shape, but the epoxy on one came loose and I need to reglue the seat pad. Anyone experienced using specific adhesive?
PostPosted: Tue Aug 26, 2014 11:27 pm
I solved with a silicone spray. The seat pads are just perfect.
I love my Hobie
Hobie Wave sail # 19491
PostPosted: Fri Sep 05, 2014 12:07 pm
Scrub the pads with a stiff brush and the blue butt situation will end. You will be surprised at how much pad will scrub off before it is solid again.
PostPosted: Wed Sep 17, 2014 1:59 am
I reglued my seat pads with Pascofix (http://www.pascofix.com/). It is the second season since then and it stil works.
Jernej
