It is currently Thu Aug 20, 2026 5:23 pm
PostPosted: Sun Jan 25, 2015 5:53 pm
This is twice now I have done this. When I first got my Wave I was lowering the mast and the mast base popped off of the ball while the pin was still inserted. I then had to use pliers to pull the pin out of the mast base because the pin had slightly bent. I straightened it out as best I could with a hammer but it wouldn't hold the mast base on the ball while lowering the mast. It kept on bending again.
I ordered a new stepping pin. After raising and lowering the mast several times I couldn't pull the stepping pin out because it developed a slight bend. The mast base didn't pop off the ball this time, but I am sure that is next. I needed pliers to get the pin out. I can't push it back in with just my fingers.
What is going on here?
PostPosted: Sun Jan 25, 2015 6:34 pm
Proper alignment of the mast when raising/lowering...
PostPosted: Sun Jan 25, 2015 7:07 pm
The Wave does require a mast pin, especially when stepping the mast. The most likely reason you're bending the pin is because the mast is not rotated, as shown on the mast decals, correctly. That's assuming the ball is the correct size and the mast base, etc. has not be somehow modified.
PostPosted: Sun Jan 25, 2015 7:33 pm
I am stepping the mast with the front of the mast facing forward.
Before I raise the mast, I clip the front side of the halyard to the mast support on the trailer.
Once I have the mast raised, I push the mast forward with my shoulder and tighten the halyard before clearing the halyard so I can attach the forestay.
If I do this too hard could this be the problem?
PostPosted: Sun Jan 25, 2015 7:50 pm
I just went outside to take a look at it. There is a decal on the starboard side of the mast that says to align the arrows when lowering the mast. That leads me to believe that lowering the mast is more critical than raising the mast. I am pretty sure the mast is aligned correctly when I raise it, but I can't remember for sure if it is aligned correctly when I lower it.
Oh well, I guess another stepping pin. I should buy them by the case.
PostPosted: Sun Jan 25, 2015 9:13 pm
Give it a go with the arrows (on the mast and crossbar) aligned and your problem will go away.
PostPosted: Mon Jan 26, 2015 6:05 am
BobV5 wrote:
Give it a go without the pin and align the arrows and your problem will go away. I never use the pin for stepping or lowering the mast. I do use it while sailing to ensure the mast is held captive when she goes over.
Will the mast base be held onto the ball when the arrows are aligned, so that it can't pop off? That is basically when the luff track is facing rearwards or downwards as the mast is raised or lowered.
PostPosted: Mon Jan 26, 2015 6:49 am
Tarzan, I've edited my previous posts. I had a similar problem to yours years ago but after looking at the manual, I'll retract my previous statements. While my previous statements may work for me, I can see how someone can get hurt stepping without the pin.
The very most important thing to keep from bending is to make sure those arrows stay aligned. That's the key.
PostPosted: Mon Jan 26, 2015 8:32 am
Thanks guys. I will see if I can straighten the stepping pin with a hammer and order another one if I can't. I will let you know if I am successful at keeping the arrows aligned and not bending my stepping pin again.
PostPosted: Mon Jan 26, 2015 10:52 am
Aligning the arrows causes the mast to be centered... with the track facing aft. The base casting has a slot that aligns with the step ball's post. You should not be able to get the ball into the base in any other position. As the mast is raised... it can rotate at some point as the post is no longer in the slot.
When you lower, you must rotate the mast to align the base with the post and slot. as you come down, the base / slot aligns with the post.
It is possible to be slightly out of alignment as the post enters the slot... the threads catch on the base casting's slot and chatter... this can cause the mast to pop/pry off the ball or bend the pin. Look for chips out of the casting and file them smooth.
PostPosted: Mon Jan 26, 2015 10:59 am
There is definitely a small gouge in the ball. It will be hard to file up inside of the mast base. I will see what I can feel.
Are you saying that as I lower the mast it should rotate into correct position all by itself!
PostPosted: Mon Jan 26, 2015 2:03 pm
Not at all. It requires some effort to keep the mast straight.
It is when it rotates a little that the threads of the post can catch on the casting and dig into it... that has the effect of prying the mast off the ball.
PostPosted: Mon Jan 26, 2015 2:44 pm
I don't know what you mean by threads on the post. The ball screws onto the front of the boat, but there are no exposed threads on it. The mast base slips over that. Where are the threads you are referencing?
PostPosted: Mon Jan 26, 2015 3:55 pm
My bad... that is an issue on all the other step systems (exposed threads), so was referencing history in that thinking. Same issue applies though. If not aligned with the post as the mast comes down it may be leveraging in some way.
PostPosted: Mon Jan 26, 2015 9:15 pm
Keeping the mast correctly aligned, per the arrows on the decals, could possibly prevent breaking the mast base casting. The mast is a giant lever and can exert a great deal of pressure.
