It is currently Thu Aug 20, 2026 4:50 pm
PostPosted: Thu Apr 28, 2016 6:28 am
Hi,
Can someone add some wisdom to adjuster settings.
Light Wind Settings - how tight/what adjuster setting should the shroud and forestay adjusters be set? Right now I have the shroud pinned 3 holes from the top.
Mast-Up Storage Settings - what settings do you recommend for mast up storage?
Finally, has anyone launched a Wave solo from a boat ramp? If so, what advice do you have and was it too difficult?
Thanks for any input!
PostPosted: Thu Apr 28, 2016 11:52 am
I've launched solo from a boat ramp that had a small area next to it where I could pull the boat up while I parked. Same in reverse. There is another ramp that has no handy 'beach' area and I've seen another Wave us a small mooring buoy arrangement. I made one for that ramp, but haven't used it yet (old 25lb barbell plate, length of line, float, and hook). You just need someplace to have the boat be safe while you mess with the vehicle.
I also installed a winch on my trailer and that really helps with getting it back on. It's light enough that I could probably do it without, on a shallow ramp, but the winch was a good investment IMO and I think really needed on a steep ramp. The hardest part for me is getting it lined up and started on the trailer rollers, then hooking on the winch without it slipping back off again! Not a big deal.
Can't help with the other questions: I don't do mast up storage and I rake my mast back for med/high wind.
