It is currently Thu Aug 20, 2026 12:34 pm
PostPosted: Wed Jun 01, 2016 5:19 pm
If you look at the underside of the hulls, where the tramp connector bar attaches (Club model), there are two threaded holes on each side. Maybe the jib cleats bolt into those holes? I just noticed that there is a small white plug in the bottom hole on each side, but the top hole is open and partially covered by the metal bar.
Do those threaded holes go through the hull or are they 'blind' holes that will not let water in?
