It is currently Thu Aug 20, 2026 1:59 pm
 Post subject: Wave crossbars
PostPosted: Tue Oct 18, 2016 1:59 pm
Again, my Wave has been in storage for quite a while. I removed the tramps to clean them and noticed the front and rear crossbars slide a little into and out of each hull. There are no end caps for the crossbars because I also have the 'back rests'.
Should there be some give in these crossbars ? Does anything actually anchor them inside the hulls ? Obviously, when the tramps are installed and laced up the tension created stops any crossbar movement.
Input ?
thanx,
bill
 Post subject: Re: Wave crossbars
PostPosted: Tue Oct 18, 2016 2:48 pm
Only the trampoline tension holds a Wave platform together. Add the rig and placed under tension locks it all together even tighter.
