It is currently Thu Aug 20, 2026 8:42 am
 Post subject: Wave Bridle anchor
PostPosted: Mon Feb 06, 2017 11:04 am
How are the bridle screws held into the hull? There is a little star crack around both screws on both sides and the deck surface may have moved up a millimeter. Are these molded in metal sleeves?
1998 Wave
2004 Getaway
Former-Hobie 16
 Post subject: Re: Wave Bridle anchor
PostPosted: Mon Feb 06, 2017 3:02 pm
The fittings are molded-in. Depends on the vintage as to what the fitting is. We started with aluminum. We changed to stainless and ended up with brass / bronze.
PostPosted: Wed Feb 08, 2017 5:08 am
OK. These are standard plastic inserts with knurled bodies, correct? How thick is the hull here? Do they stay put unless abused?
1998 Wave
2004 Getaway
Former-Hobie 16
PostPosted: Wed Feb 08, 2017 9:34 am
To be clear again: We started with aluminum. We changed to stainless and ended up with brass / bronze.
The insert looks like a dog bone and is well covered by plastic. Very rare to have an issue except for the old aluminum ones that could corrode and expand which can fail the plastic. We made a stainless strap kit to hold those in place, so over all... not been a problem with complete failure.
