It is currently Thu Aug 20, 2026 1:59 pm
PostPosted: Thu Aug 03, 2017 8:24 pm
Has anyone discovered vinyl numbers that adhere to the rotomolded hull? Every type of number I try eventually falls. Any advice would be appreciated!
PostPosted: Fri Aug 04, 2017 9:53 am
I got some permanent vinyl letters and numbers from Menards. They stuck to my TI like you wouldn't believe. Had them on for over a year without any sign of coming off. I peeled them off a couple of weekends ago (took a razor blade) because Ohio doesn't require them. Now I've got ghost hull numbers :lol: I did prep the surface with rubbing alcohol first.
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Kayakbob's Sprayskirts
  • Spine Board Hakas
PostPosted: Fri Aug 04, 2017 10:13 am
I've had these on for 3 years and no issues yet: https://www.amazon.com/gp/product/B004L ... UTF8&psc=1
I also used this to promote adhesion: https://www.amazon.com/gp/product/B0088 ... UTF8&psc=1
PostPosted: Fri Aug 04, 2017 7:18 pm
Thanks for the advice....just placed an order from Amazon for letters/numbers and adhesive promoter
