It is currently Thu Aug 20, 2026 12:44 pm
 Post subject: How to fix a split mast?
PostPosted: Fri Dec 01, 2017 4:04 pm
Hello. New Hobie Wave owner and first time poster.
I have a split in my mast. Photo here: https://photos.app.goo.gl/hf27oSDSPQoPgGtt1
- Can i fix this? How?
- Should I fix it? The previous owner said it's been like this for years.
Any thoughts /advice are greatly appreciated.
Thanks.
PostPosted: Mon Dec 04, 2017 8:47 am
That is not good. The mast should be replaced. Was caused by water freezing inside the extrusion. The is a dangerous crack that could cut or pinch upon failure let alone strand you on the water.
PostPosted: Mon Dec 04, 2017 9:42 am
Hi Matt. Thanks for the quick response. I was thinking of trying to fix it via 'brazing'. Bad idea?
https://www.youtube.com/watch?v=3SBfP4_i1Go
Also, if not fixable:
- Who do i contact in Canada (ideally in the Vancouver area) to get a buy mast? I see you are with Hobie US and i can't find a contact for Hobie Canada.
- And do i just need a mast base? Or would i need to order the whole thing?
Again, thanks very much for your assistance.
Craig.
PostPosted: Mon Dec 04, 2017 3:57 pm
Hi Craig,
Unfortunately the mast is a highly stressed part of the boat. Flex and loads would not be held by a repair.
The lower mast is available
38583141
MAST WAVE LOWER, NEWER TYPE (BALL TYPE STEP ON CROSSBAR / SOCKET IN MAST BASE)
SER #1438 UP. OLDER REQ NEW STEP
US$ 514.00 (12/2017)
We have dealers in Canada. Try our "Dealer Finder"... choose Rotomolded Sailboats as the product type.
https://www.hobie.com/dealers/
PostPosted: Mon Dec 04, 2017 6:22 pm
Much appreciated Matt.
Cheers. Craig.
