It is currently Thu Aug 20, 2026 1:51 pm
PostPosted: Wed Jul 25, 2018 2:13 pm
Hello. As mentioned in previous posts, I recently bought a Classic Hobie wave. Really loving it.
I'm about to place an order for a replacement cam kit. Before I place the order I'm wondering what extra parts a Hobie Wave owner should have on hand (I don't live close to a store in which I can quickly get replacement parts). I have sail tape and a few clevis pins and shackles. Is there anything else that I should have ready?
Again, many thanks. Craig.
PostPosted: Wed Jul 25, 2018 2:16 pm
buy the bag of extra pins
it comes with the pin for the mast and forestays
I got one for like 10 bucks
if you drop one go to bag and you sailing again in 5 min rather than 2 weeks
Sent from my SM-G950W using Tapatalk
PostPosted: Wed Jul 25, 2018 3:18 pm
I have a spare drain plug.
PostPosted: Wed Jul 25, 2018 3:20 pm
great idea I need to get one of them.
PostPosted: Wed Jul 25, 2018 7:29 pm
Ring dings.
PostPosted: Fri Jul 27, 2018 9:52 am
CA Newbie wrote:
Ring dings.
what is a this
PostPosted: Fri Jul 27, 2018 12:06 pm
imfsub12 wrote:
CA Newbie wrote:
Ring dings.
what is a this
The circular clips that install into the holes in the ends of clevis pins to keep them from falling out. Also known as split rings.
PostPosted: Fri Jul 27, 2018 5:03 pm
srm wrote:
imfsub12 wrote:
CA Newbie wrote:
Ring dings.
what is a this
ah that's why I said the bag of stuff.
it has it all in there for parts
[emoji41]
PostPosted: Fri Jul 27, 2018 6:15 pm
Also for classic I strogly recommend have spare set of stuff that screwed into crossbar: square nuts, bolts and tangs.
PostPosted: Sat Aug 11, 2018 5:35 am
Electrical tape. I use the cheap stuff. Wrap everything. ALL RING-DINGS MUST BE TAPED. About three wraps around the swages on the stays to protect the mast, the forestay adjuster, the side stay adjusters under the vinyl covers, anything that you find that is sharp. Swimming expeditions usually happen unexpectedly.
Maybe a couple of pieces of modern super strength 1/8" line. It's amazing what you can tie back together.
What I end up loaning to people is a mast erecting pin (with a big tag on like a gas station washroom key), and a thin wall socket to adjust your rudder engagement. You can buy an expensive one from Snap-On or grind down a cheapish one. A really cheap one will break, I know it's not helpful for me not to tell you what size but mine, of course, has the markings ground off :D . You might try 5/16", everything else is, so ....
Great boat isn't it?
