It is currently Thu Aug 20, 2026 2:55 pm
PostPosted: Sat Feb 09, 2019 11:08 pm
Where/how do I get the reinforcement straps/bolt kit they created for early waves?
The boat I just bought will need this. There’s a little stress crack near the strap I need to repair then reinforce.
If unavailable is there a design sheet or specs so I can fab 2 of these these myself?
I found the tech instructions on the wave support files section of the site but dint see part numbers etc.
PostPosted: Sun Feb 10, 2019 12:12 pm
No longer offered. Basic concept... you can get from the instruction. Strap over the hull to hold the insert in... or the strap can become the new bow tang too.
PostPosted: Wed Feb 13, 2019 7:15 pm
Thank you Matt. I ended up speaking with your counterpart (who had an awful cold that day!) and he gave me the old part number and suggested if I wanted one to search online/ebay as a dealer might have one out there. Part #38120201 he said. I found a listing if I want it from a dealer.
He actually suggested I gflex the tiny crack and leave it alone - since the crack is small and to the left/below the eye he said it's not failing in the way the kit was designed to address. He also said they failed quickly and pulled out and I should just g flex it, touch it up w white pain and let it be/keep an eye on it and try to avoid hole drilling in hull to install the kit.
Let me know if you have a different viewpoint though.
PostPosted: Thu Feb 14, 2019 4:42 pm
That all works. If the insert does pull out you need to do the strap. G Flex is not going to hold it in.
