It is currently Thu Aug 20, 2026 8:52 am
PostPosted: Tue Jun 08, 2021 10:16 am
So I bought a used '97 Wave SE for a couple hundred and it looks like I will be at a grand and counting on replacement/missing parts.
The mast is damaged, so cut off the bottom 10 mm(3/8"), but just realized this will effect my forestay and shrouds lengths. Will this 3/8" make a difference? I assume I can make up the difference in the forestay with the 7 hole adjuster.
If the 3/8" makes a difference on the shrouds, what are my options? Raise the tang 10 mm? Replace the shrouds with Club versions and add adjusters? Anything else I am missing?
Should I sell what I have for parts and start over?
https://www.amazon.com/photos/shared/VD ... rfo6CEZSkx
PostPosted: Wed Jun 09, 2021 7:51 am
I would try to go with club shrouds with adjustments solution. Reasons:
1. Relatively cheap.
2. Reversible. If it won't work (it should:) ), you may return shrouds and try another solution.
3. Worth doing anyway, considering boat condition.
