It is currently Thu Aug 20, 2026 9:42 am
PostPosted: Mon Mar 21, 2022 6:33 pm
What is the best method to remove the glue residue used to mount Hobie seat pads? I think I used contact cement. It was a long time ago. Most of it came off but there is still a little left.
Is there a replacement alternative to the stock Hobie replacement pads? Something homemade would be fine. Whether a stock Hobie Wave pad or an alternative, what did you use for glue?
PostPosted: Tue Mar 22, 2022 3:28 am
A small paint scraper works well at a shallow angle to remove the glue. Also, course grit sandpaper works too! I have seen folks using the SUP foam padding cut to fit. I went ahead and replaced mine with the Hobie product. Whatever you chose, get the sticky back type and also use contact cement to solidify the front and rear sections so they don't come up in use/trailering. Have fun!
:wink:
Bob Curry
Master Unirig Sailor
PostPosted: Tue Mar 22, 2022 6:29 am
GooGone and patience :)
Contact cement works well for me if I follow every single letter of instructions.
PostPosted: Tue May 03, 2022 8:46 pm
I just bought new Hobie Wave pads and they come with 3M adhesive already on the bottom. I assume no contact cement if it has 3M adhesive already on the pad?
Scott
Hobie 18 w/wings
Hobie/Holder 12 Funseeker
2 Hobie Waves
Tandem Oasis Kayak
Hobie 16
Southern California
PostPosted: Wed May 04, 2022 5:51 pm
Because of windage while trailering, I always add some contact cement to the front parts of the pads. The rest should be fine with the backing removed.
Bob :wink:
Bob Curry
PostPosted: Mon Aug 29, 2022 7:06 pm
Re: Goo Gone, any concerns of it affecting the hull material? From what I recall goo gone says to be careful on certain plastics :?:
PostPosted: Tue Aug 30, 2022 5:29 am
Hulls themselves will be fine. Glue, that seals inspections ports, will be dissolved, but it is good idea to reseal them with something like 3M 4200 anyway.
PostPosted: Wed Aug 31, 2022 11:21 am
I used Goo Gone on my hulls, no only did it do a great job of removing the old adhesive, it cleaned up rusty waterline stains really well with a Magic Eraser.
