It is currently Thu Aug 20, 2026 8:52 am
 Post subject: Mast step base question
PostPosted: Sat Apr 08, 2023 7:55 am
I’d like to replace the base of my mast. I have a replacement base but as I look at the current base it appears to have a rivet securing it to the mast whereas the replacement (pic below of the one I have on hand) has no holes to accommodate a rivet. Does the replacement just press-fit? Any special tips or guidance? Thanks!
https://westcoastsailing.net/hobie-wave ... g-current/
PostPosted: Sat Apr 08, 2023 12:06 pm
Castings are not pre-drilled. You will press in place and then drill for the rivets.
PostPosted: Sat Apr 08, 2023 6:24 pm
Thanks Matt. Any advice on what rivets (diameter, length, material) to use?
PostPosted: Sun Apr 09, 2023 9:25 am
There is a parts guide on the support pages of this site: https://www.hobie.com/support/wave/
Rivets: 8010131 (3) RIVET POP 3/16 x 3/8 PH-SS (Stainless Steel 3/16 Diameter)
PostPosted: Sun Apr 09, 2023 6:49 pm
Many thanks Matt!
