It is currently Thu Aug 20, 2026 8:52 am
PostPosted: Fri Feb 28, 2025 12:00 pm
Hi all,
Got brand new Wave, assambled it as per manual, after installing 2 side shrods and raing the mast it's just impossibe to install the forestay into the adjuster. It feels like it's too short and I missing like 5 Cm of length.
All cables, hrouds, brides re correct, it's just the middle firsestay coming down from the mast cat reach into the adjuster.
Any ideas? Maybe use carabiners as an extension?
Dan.
PostPosted: Sat Mar 01, 2025 5:40 pm
Possibly a silly question, but which hole do you have the shrouds in on either side? IIRC mine are on about the 3rd or 4th hole from the bottom to start with, then I lower them down after I've rigged the forestay.
PostPosted: Sat Mar 01, 2025 9:52 pm
My side shrouds are in ths 1st hole (upper ones). I understand that all the wires are new, tight and supposed to be hard to install but the front forestay is just impossible. I extended it with 2 carabiners for now, hoping the forestay will get long with time.
PostPosted: Sun Mar 02, 2025 3:38 pm
Check shroud, forestay, and bridle wire lengths vs. the Hobie wire guide. https://media.hobie.com/2010_archive/support/pdfs/WireGuide.pdf
Comptip fully inserted into the lower mast?
Do you have the shrouds with the pin in the top hole of the adjuster to start with?
Use a 10-hole adjuster for the forestay.
PostPosted: Fri Mar 07, 2025 1:04 pm
Hobie Tech / Moderator
T82d wrote:
Hi all,
Dan.
Dan, sorry to hear the hassle you are having. Can you send me an email? [email protected]
Steve Fields
VP Hobie Sailboats Worldwide
