It is currently Wed Aug 12, 2026 3:03 pm
PostPosted: Fri Aug 28, 2015 2:31 pm
I have an 08 Outback. Will the new GT drive fit? It looks different than the older drives, so im guessing no, but want to confirm.
PostPosted: Fri Aug 28, 2015 3:10 pm
They do fit in older kayaks, all you need to do it remove the alignment pin from the spine, but beyond that small modification it will fit.
Jacques Bernier
http://www.hobie.com/
PostPosted: Sat Aug 29, 2015 9:42 pm
Thanks Jacques. I'm clueless - where is the alignment pin and how would I remove it?
PostPosted: Sun Aug 30, 2015 6:33 am
Check out this Hobie link. viewtopic.php?f=60&t=46677
You need to cut off the plastic alignment pins. It's quite obvious once you have the new drive in your hands :wink:
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Sun Aug 30, 2015 8:43 am
Ok, thanks for your help!
