It is currently Wed Aug 12, 2026 1:41 am
 Post subject: Hobie Livewell MOD
PostPosted: Mon May 12, 2008 6:08 pm
Sorry for the delay
heres pics plus somewhat detailed instructions
2 x (1/4" )female threaded pvc elbow with mips fitting
1 3" section tubing
Locate ring holding tsunami pump in place on underside
Remove ring
Remove pump from well and add elbow # 1 to threaded outlet (the tube thats normally inside the livewell)
Place back in livewell and re-connect ring
(no pic)
Take section of tubing and add 2nd pvc elbow
This 2nd elbow will become your new outlet
I choose this fitting cuz I had it
I believe a fitting is need here so water sdoesn't just spout up and you have a little control of how the water flows
Take tube and connect to mips fitting on pump (DONE !!!)
Adjust as necessary
Hope this helps
MikeG
Hobie Mirage Revolution
Ocean Kayak Prowler 13
- Look ma no hands
PostPosted: Mon May 12, 2008 9:04 pm
MG, great how-to with excellent illustrations. Thanks!! 8)
 Post subject: Re: Hobie Livewell MOD
PostPosted: Thu Oct 20, 2022 5:02 pm
Why can't I see the photos you uploaded? :(
PostPosted: Fri Oct 21, 2022 1:00 pm
Hobie does not provide a forum solution that stores photos. This requires every forum poster to select a image hosting provider that works with this forum software. As these image hosting companies have been shut down or acquired over the years, the hosted photos have been lost or deleted. Many of these companies provided services for free and did not have viable business models. Thus, this forum is now full of broken image links.
Peter
2016 Hobie Oasis with Evolve v2 rudder mount, Sidekick ama kit, Mirage sail kit, Garmin echoMAP CHIRP 42dv, bilge pump
2007 Hobie Outfitter x 2 with Mirage sail kits, large rudder blades
PostPosted: Fri Oct 21, 2022 4:50 pm
Peter
Thank you for your kind and fast response.
It would be very good to be able to see the photos that the fellow fishermen have placed in their explanations over these years...
Have a nice day!
