It is currently Wed Aug 12, 2026 6:45 am
PostPosted: Mon Nov 02, 2009 9:10 am
I just got a Hobie Adventure, and absolutely love it! Quick question on transport:
I have a factory roof rack and cross bars on my car, and use the standard foam blocks for loading the kayak. Should I try to avoid strapping down right under the Mirage Drive well (so the well is on the block). The straps cause a bit of pressure - is there an optimal place to align the bars/straps?
Thanks-
PostPosted: Mon Nov 02, 2009 10:00 pm
Tidalist, congratulations on your new Adventure and welcome to the forum. Foam blocks are better than nothing, but either flipping the boat upside down or using proper saddles would probably make the boat ride better.
The Drivewell is a strong point on the boat if it is riding on its bottom, so this should be over the cross bar if proper balance permits. Although it takes a little longer, I use two ropes at the well, one anchoring at each side of the rack. This positively secures your boat to the rack and you don't have to cinch it so tight and risk denting it. Even if it slides around a little, it won't go very far!
For the rear tie-down, again I find rope more adaptable than straps, and loop around the boat once so it doesn't want to slide-to-side.
There are many other ways to accomplish the safe transport of your boat however -- as long as it doesn't fall off or get crushed! 8)
