It is currently Wed Aug 12, 2026 12:17 pm
PostPosted: Tue Oct 12, 2010 9:26 pm
Hi,
Can the diamond RAM mount (1.5" ball) be used for trolling? I know the 1" ball is used for electronics. Thanks.
http://www.ram-mount.com/CatalogResults ... fault.aspx
PostPosted: Wed Oct 13, 2010 9:54 am
It can, but it really depends on how big of rods you are looking to run and the size of the fish targeting. I had them on my Revo but I went to the Scotty because they can be locked in. I had some big hits/screamers pull the ram Tubes down. They will work as a rod holder but I can't trust them. read this thread:
viewtopic.php?f=69&t=23007&start=15
http://s909.photobucket.com/albums/ac294/gsammy925/
PostPosted: Wed Oct 13, 2010 12:34 pm
Thanks for the reply...
PostPosted: Wed Nov 03, 2010 10:45 pm
Or buy a RAM rod holder with a bulkhead mount instead of a ball mount. Almost exactly the same as Scotty style. Most Hobie kayak dealers just have the ball mount styles as thats what Hobie supply to them, but some others have expanded their range. Difficulty getting sockets to lock onto sockets is obviously the inspiration for that.
Kayak Fishing Specialist: SLH
https://slhobie.com.au
PostPosted: Thu Nov 04, 2010 7:12 pm
Nothing wrong with the low profile Scotty versions, except when you like making adjustments on the water.
Mine Aka mounted RAM balls are holding out well, sailing hard with the AI and trolling large bait. No 30+lb strikes yet, but my drag is set under 10 lbs anyway. All is good.
The drier your balls are, the better. I would advise roughing them up a bit with sandpaper and keeping a tight grip. Use the shortest extension possible. Long tubes are the easiest to bend.
Also choose the salt water rated METAL versions of the mount and sockets. They will grip better.
The Wind Is Your Friend...
PostPosted: Mon Nov 08, 2010 8:13 pm
Much agreed.
I tried both of those, The super-models were simply appalled. :lol: :lol: :lol:
