It is currently Wed Aug 12, 2026 2:17 pm
PostPosted: Mon Apr 25, 2011 2:43 pm
I dont mind buying the hobie anchor trolley kit, I just dont want to drill holes in my kayak.
Is there a way to install an anchor trolley on a Hobie Outback without drilling any holes?
Thanks,
Twin
PostPosted: Tue Apr 26, 2011 2:38 am
Not without having the rope in your lap.I just installed one this past week,Hobie did their homework and made it easy.Seal the couple litttle holes and you're ok..........................
Robin
PostPosted: Fri Apr 29, 2011 6:20 am
I was nervous about drilling holes when I first starting fishing out of a kayak, but after a while, you get used to it. I just drilled the four holes for the two pad-eyes and bolted it in. It is fine. I made sure the holes were above the water-line.
legocrusader,
PostPosted: Tue May 03, 2011 7:53 pm
It's not yours till you drill some holes in it.
Mike
2015 Pro Angler 12
Yellow with Humminbird side imaging
PostPosted: Sun Jul 10, 2011 1:21 pm
Try this link:
http://www.youtube.com/watch?v=klMnRjrV ... re=related
Thanks,
Twin
2009 Oasis
2012 Freedom Hawk Pathfinder
PostPosted: Mon Jul 11, 2011 9:33 am
Before you drill any holes, make sure you are not going to hit one of the cables inside the hull!
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Sun Aug 14, 2011 3:26 pm
Ive seen trolley systems that anchor to the front and rear T handles,or front Thandle to side carry handle.Dont know how well it works.
