It is currently Mon Aug 10, 2026 3:47 pm
PostPosted: Fri Jan 20, 2012 4:06 am
Was wounding if it possible to have the same controls for the rudder as the mirage drive kayaks on a quest 11
with the up and down controls on both sides one for up the other for down?
if there is a kit please post.
PostPosted: Fri Jan 20, 2012 9:25 am
There is a rudder kit available - part number 78502 (available from any Hobie Dealer - call toll free 1800hobie49 - or click the dealer finder here: http://www.hobiecat.com/support/dealers/search/ )
The up/down function is external and not run into the hull to make it simpler to install. Shoot me an e mail and I'll send you a copy of the installation instructions to look at.
PostPosted: Fri Jan 20, 2012 1:21 pm
i know about the one with the control running up and down the side of kayak
but has anyone tried to run them inside like in this guide page 9 http://2010.archive.hobiecat.com/support/pdfs/Twist-n-Stow_Repair_Manual.pdf
PostPosted: Fri Jan 20, 2012 2:33 pm
Ah - OK.... didn't catch that in your first post
You 'could' do this internally ran up/down setup, it would just be custom... we don't have a 'kit' version of the parts - you can buy the individual pieces easily though, they are all available separately from your Hobie supplier (I notice you're in Australia - so you'd have all the same parts that we do here in the USA as well)
You'll need some turning blocks for the strings to run around - screws and nuts to mount the blocks, and of course the handles and lines.
All the parts can be seen and part numbers found on pages 36 & 37 of our accessory catalog. If you don't have a printed copy - its also a free download here: http://www.hobiecat.com/support/catalog-request/
PostPosted: Sat Jan 21, 2012 2:26 am
Jbernier can you tell me if the 2011-12 quest 11 do have the spots were up & down cord can go on the rear near rudder like the rev 11 a pic of a quest rear would help.
PostPosted: Mon Jan 23, 2012 9:42 am
Yes - the Quest 11 has all the same hole indexes there if you choose you can drill them out and install tubes like on the Revo (or any other Mirage kayak for that matter)
FYI: The Quest and Revo 11's are only 2012 models, neither were available as 2011 models.
PostPosted: Mon Jan 23, 2012 12:24 pm
Thanks will post pic if i do the mod
thanks again
