It is currently Thu Aug 13, 2026 12:23 am
PostPosted: Sun Jun 01, 2014 7:42 am
I recently installed the Hobie power pole mount item no. 72020176 on my PA 12. In the directions the forth step 4,states to reuse the screws removed from the rudder cover. The screws are 1/4 inch too short. I recommend that 2,10-32 x 3/4 screws be used instead. Make sure to get stainless steel. They are available at your local hardware store. This will prevent the threads from being strippen when tightened.
I will be posting a full Micro pole install directions with pictures soon.
Steve McNerney
Hobie Fishing team member.
PostPosted: Sun Jun 01, 2014 9:10 am
I also found that the bolts for the rear handle clamps are to short. Like said above, just go to the hardware store and buy SS bolts in the next size longer. Other than that, the install was eazy peazy :D
PostPosted: Mon Jun 02, 2014 6:17 am
The screws that were included with mine worked perfect, front & back.
PostPosted: Mon Jun 02, 2014 6:49 am
Maybe I need to put my fat PA on a diet :mrgreen:
PostPosted: Thu Jun 05, 2014 11:43 am
Mine worked fine on the rudder cover, however the bolts for the clamps are a bit short. I was able to secure them however I will probably replace with longer ones just to be safe.
