It is currently Thu May 14, 2026 6:44 am
 Post subject: Transducer?
PostPosted: Sat Sep 13, 2014 5:50 pm
What is the best place to instal a transducer on a oasis Front,Middle or back
 Post subject: Re: Transducer?
PostPosted: Sat Sep 13, 2014 6:36 pm
Front...it needs to be forward of the Mirage Drive to prevent interference from the fins.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Sat Sep 13, 2014 9:25 pm
That is what I though but if you look at the Hobie kayaks that have transducer mount pre installed it looks like is on the back of the kayak
PostPosted: Sun Sep 14, 2014 7:01 am
That's a good observation......the transducer location on my PA-14 is at the back end of the seat and this location, on a "non-transducer pocket-mount hull", is not real easy to access.
On my previous 2010 Outback, access through the forward hatch is a snap.......I installed the transducer just forward of the sail mast tube (a flat surface is important) using "Duct Seal" I bought in the electrical department at Home Depot....a 1 pound pug is under $3.00.
If you clean/degrease the area with alcohol first, place the transducer flat/flush on the hull and then use the Duct Seal like modeling clay to hold the transducer in place.
There are several threads on this technique.....it works well, no air bubbles to worry about degrading the signal and if you want, the transducer removal or relocation is easy to do.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Fri Oct 03, 2014 8:49 am
I put mine right in the middle between the drives and it has always worked flawlessly.
2011 Oasis with Sail and AMA's
2011 Necky Looksha 14
