It is currently Wed Aug 12, 2026 2:58 pm
PostPosted: Sat Oct 04, 2014 11:09 am
The power cable for my Lowrance Elite-4 HDI has 2 wires. The second one is an NMEA Data Cable. I am not going to use it, but it's not removable.
Problem is, the plugs provided by Hobie only have 2 holes. I would need 3 (2 for the power cable, and one for the transducer cable).
The only solution I can think of is to cut the data cable near the connector, but that doesn't sound smart. Any better ideas?
2011 Oasis - Lunalilo Express
2012 Revo 11 - Lunalilo
 Post subject: cut it
PostPosted: Sat Oct 04, 2014 6:30 pm
yes I cut it on mine I called lowrange and they said it can be cut if you are not going to use it
PostPosted: Sun Oct 05, 2014 12:58 pm
One is for the NMEA connection so it can be connected to a VHF radio or other device. Not needed with a kayak. You can cut off all but 3" and tape the end of this wire. Check the instructions so you cut the correct wire.
PostPosted: Sun Nov 16, 2014 6:04 pm
use epoxy to waterproof seal it. just a lil dab of 5-min epoxy.
cheers
drew
Cathedra Mea, Regulae Meae.
PostPosted: Sat Nov 29, 2014 8:44 pm
this might be a little late, but I cut mine about 2 inches down and coated it with that plasti-dip stuff. I did like 3 or 4 coats. Then I ended up taping it to the power wire to look clean. If I thought about it before hand, I would have tried sliding some heat shrink tubing over the 2 wires just to hold them together neatly.
PostPosted: Fri Jan 16, 2015 9:32 pm
You can pickup an additional thru hull fitting from your local dealer. it will come with all of the adapters needed for different wires. I install the second plug about 2-3 inches away from the other. put transducer wire through one and power/data cable through other.
PostPosted: Sun Jan 18, 2015 10:28 am
I also used an additional plub. I just clipped the exposed wires at the end of the outide cover though and sealed them off just in case I want to sell the fish finder and upgrade to a different unit.
