It is currently Wed Aug 12, 2026 7:13 pm
 Post subject: Squeaky seat
PostPosted: Tue Nov 18, 2014 2:18 pm
The seat on my new 2015 Outback squeaks incessantly while I am pedaling. Any thoughts on how to reduce the noise? I troll a lot, and it's getting nerve wracking! Of course, the noise is scaring the fish which is why I'm not catching any.... :oops:
 Post subject: Re: Squeaky seat
PostPosted: Tue Nov 18, 2014 4:52 pm
I had the same issue with my 2013 PA-14 seat....finally tried "Pure Silicone Lubricant" spray from Ace Hardware.......that did the job.
"Liberally" spray the seat and back, make sure you cover the aluminum frame rails where the material wraps around it.....let air dry for an hour and then I wiped the surfaces with an old t-shirt. No MO-Squeak 8)
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Tue Nov 18, 2014 6:17 pm
Its where the vinyl touches the frame I bet.
PostPosted: Fri Nov 21, 2014 11:34 am
Thanks. I'll give it a try and let you know.
PostPosted: Wed Dec 03, 2014 1:52 pm
Worked like a charm. Thanks for the common sense help!
PostPosted: Wed Dec 03, 2014 9:00 pm
Excellent :!:
Dr.SteelheadCatcher
Warrenton, OR
