It is currently Wed Aug 12, 2026 2:58 pm
PostPosted: Mon Mar 09, 2015 8:25 pm
My JL Marine Power-Pole Micro Anchor was getting pretty bored sitting on the garage shelf, so I finally ordered the YakAttack Micro Mount for the new Outback.
After a quick consultation with fellow HFT member Hanover_Yakker up in Virginia, I started the install.
I'll skip over most of the instruction, as Chuck covers it quite well on his blog- http://froggin4bass.blogspot.com/2015/0 ... hobie.html
I'll just comment about the two addition steps that I added;
1- I used a West Marine (modified) thru-deck fitting to run the power cable to the 12v9ah battery located in the rear hatch. With a quick shot of marine silicon, the fitting is water-tight.
2- I installed a RAM 1" ball to act as a rudder blade stop and the connection point for the rudder storage bungee.
Hole drilled for Micro's power cord, tight tolerances require less silicon to seal.
Thru-deck fitting which is covered by the mounting board.
Hobie Battery Mount holding a 12v9ah unit.
Bungee mount relocated from the starboard to port side.
Ram ball keeps the oversized sailing blade from impacting the Micro and helps secure the bungee which in-turn secures the rudder for transport. Having the bungee on top of & under the blade keeps it from chaffing on mount while traveling.
Ready to hit the waters of the Indian River (shown with quick-release cord installed).
These may not be for everybody, but I love the ease of using the Micro........
~YakAttack Pro Staff ~ LIVE Watersports Pro Staff ~ RAM Pro Staff ~ Power-Pole Micro Pro Staff ~ Columbia Pro Team~
PostPosted: Fri Mar 20, 2015 11:14 am
Looks great, thanks for the pics and tips, getting ready to install on my 2008 OB.
May the holes in your net be no larger than the fish in it. ~Irish Blessing
JFC
'13 Revo
'16 Outback x 2
PostPosted: Fri Mar 20, 2015 6:58 pm
Clean! I am installing one on my PA soon I am going to go with the Railblaza mount. Figured if I am going to spend 5k on a yak it's not that crazy to spend 600 on an anchor =)
