It is currently Wed Aug 12, 2026 3:56 pm
PostPosted: Sun Dec 27, 2015 11:43 am
Has anyone started to mount their gear slide tracks and/or fish finder on the new yaks? I'm wondering how the foam padding in the side trays and cup folder impact mounting hardware. Please let me know your thoughts. Thanks!
PostPosted: Mon Dec 28, 2015 1:13 pm
You will need to remove the foam under the track or mount if you want a firm seat.
I have never been even remotely hesitant to drill holes in a yak before this one....
I am going with 3M VHB ( do a google search on it ) tape for mounting most of my accessories. It will hold anything, just do not use a citrus cleaner on it. I used it on mounting my Humminbird SI on my PA last year and it has never loosened.
best of luck, Phill
www.dallascnc.com
PostPosted: Mon Dec 28, 2015 10:23 pm
Thanks Carver! Do you have any pictures of your gear mounted with this tape? Just looking for some ideas. I see some people have gone with the H bar instead. Similar this. Image
PostPosted: Tue Dec 29, 2015 10:13 am
I'm not near my yaks for a couple of days to get a pic, but I only use it when I have a bit of surface area like under a track or under my exterior led lights. It is just a really strong double sided tape. 3m claims on aluminum to aluminum it is stronger than a weld. They have some pretty impressive videos where the tape joint out does a weld when tested for impact from a falling bowling ball repeatedly.
I have also used it to secure some 1" ram balls for other things.
PostPosted: Tue Dec 29, 2015 10:56 am
I would recommend instead stick to gear tracks that are flush against the hull. You can add a ton of different attachments too, but keeps a low profile. The H Rails will get bang up like that. People will try and use them as handles and makes it tuff to store the boat sometimes too. Just my 2cents.
